The Time Calculator is available in two separate functional areas:  The Home Screen and within a Flight.  The Home screen time calculator allows you to use time calculator functionality separate from calculations within flights.  Each flight also has its own unique time calculator that will remember the entries within the flight so you can add start/end times for each flight for those wanting to add up a total time for the day and make a single flight log entry.
Usage
Enter the start and end "time" in 24 HR format such as 1400 and 1535.  The times must be in the same time zone, i.e. UTC if you fly across time zones.  Once a start and end time are entered tap "Add Interval" to add the block time and calculate a duration for the leg and add it to the total duration shown.  Time conversions are done on a per leg basis as if you logged each leg separately and then the total for each leg are added to get the total for all legs calculated.  When used in a flight you can tap the down arrow to transfer the time calculator time to the duration field.  If using the Home screen time calculator you can tap the copy button then paste the value where desired.
Editing
You can remove legs by swiping to delete or using the Edit button on the top right then delete the legs as desired.
The time calculator can be hidden from the Flight entry screen if it's not something you want to use.  To hide the time calculator go to Settings / Flight Log / Configure Display (at the bottom)
urlhttps://www.youtube.com/watch?v=pfhI5KGIzVY&list=PLt5jhPpkokeJjEzaYRlJkG4EFFXdPs4CI&index=15
