Note |
Standard payroll categories can be edited but cannot be deleted. |
The payroll category title is displayed at the top. This title can be edited if desired.
Payroll Categories can be archived or deleted by swiping left on the Payroll Categories list.
Tap the "+" at the top right to add a custom Payroll Category. Configure the details as desired.
An important note about the Canceled Prior To Duty payroll category. APDL will not allow the Duty On time to be set after the departure time of the first leg. This includes a canceled leg in the event that the leg is canceled after you report for duty. The Canceled Prior To Duty payroll category is intended to be used when a leg is canceled prior to reporting for duty and your Duty On time is therefore adjusted to a later time. If the Canceled Prior To Duty payroll category is selected, APDL will allow you to adjust the Duty On time after the scheduled departure time of the canceled leg. This allows your duty calculations to be correct while also allowing you to keep the canceled leg in APDL for payroll tracking purposes.
