Page tree
Comment: Published by Scroll Versions from space APDLDOC and version 9.1.0
The number of aircraft associated with this aircraft type is displayed on the Aircraft row. You can tap that row to view all the aircraft in a list.
The Typed Type Rating switch is used to designate if you have a type rating in the aircraft.
The Rest Facility Row here sets the rest facility for this particular aircraft. This will initially be set by the aircraft type's default rest facility, but you may need to change it if certain specific aircraft within the same fleet have different rest facilities at your airline. If you need to change the rest facility for a specific flight due to inoperative equipment, you can do that for just one flight at a time on the Leg View page.
