Sync on Start:
Sync on Exit:
Just like Sync on Start except sync occurs when leaving the app (suspend or close)Performs a sync with the cloud when the app is closed, the sync progress occurs in the background and is not visible nor do you have to wait for it to complete.
Sync Pending Flights:
The default option is not to sync Pending Flights, i.e. flights not yet flown typically used by airline pilots importing future flights via the schedule importer. However, for airline pilots, etc. that may need their FAR 121/135 reports updated to reflect future flying to check limits syncing pending flights may be of value. Set ON to allow pending flights to be synced. Note: As Logbook Pro PC edition desktop reviews your flight log for erroneous entries, i.e. a row of information that does not meet the minimum required fields of Date, Type, Ident, Route, and Duration (or SIM) pending flight data could be auto purged on the PC side. If you set Sync Pending Flights to ON you should go into Logbook Pro PC editiondesktop's Options/Flight Log area and clear the bottom most checkbox.
This feature has been removed in version 5.x and later. To purge synced information after sync is confirmed in Logbook Pro desktop, tap the trash can (purge button) and choose Purge Synced.
Time Zone:
Set the desired time zone for the Flight's OUT, Takeoff, Landing, and IN (OOOI) times to one of the three options: Device Local, UTC, or Custom. Data will be converted to this time zone when synced back to Logbook Pro PC editiondesktop. Click here to learn more about time zone options.
