Sync on Exit
Performs a sync with the cloud when the app is closed, the sync progress occurs in the background and is not visible nor do you have to wait for it to complete.
Sync Pending Flights
On-Demand Sync
You can command a sync from just about any screen in the app using either a two-finger vertical swipe or a double-tap in empty areas such as the grey areas around content. If you don't want to use this functionality you can option it OFF as indicated above.
Reset all data to Unsynced
