This is a minor update to a stable platform addressing various feedback items and enhancing the app in our continual development process.
  • Prevent double-tapping in edit fields while data areas are in edit mode that trigger sync (double-tap on sync)
  • When deleting an item from the data views the DONE button does not switch back to EDIT
  • Improvements for setup wizard and sign in/out logic
