You can command a sync from just about any screen in the app using either a two-finger vertical swipe or a by double-tap tapping in empty areas such as the grey areas around content. If you don't want to use this functionality you can option it OFF as indicated above. (Note: Two finger swipe was removed in 5.9.6)
Reset all data to Unsynced
Note: Swipe to Sync was removed in 5.9.6
