Each leg also contains a Regulation section. By default, Regulation for each leg is Automatic.
With Automatic selected, the regulation type used to compute your duty period legality is based on the most restrictive leg type.
- Acclimated Theater: An assumption is made for where the flightcrew member is acclimated, but if the assumption is not correct the acclimated theater, or airport, can be changed.
- Acclimated Time: As with Acclimated Theater, it is not known exactly when a flighcrew member has been in a theater long enough to be acclimated per § 117.3 Definitions. This alters the start time when calculating FDP and flight time.
- Flight Segments: If additional flight segments are to be flown that are not yet entered into APDL, that can be adjusted here.
- Acclimated: Indicates the flightcrew member is acclimated to the scheduled theater. If, for any reason, this is not the case, that can be indicated here. For the most part this reduces maximum FDP for a duty period.
- Two buttons at the bottom of the Assumptions section were added to recalculate and reset the assumptions.
If all activities for a certain day only contain Part 91 flights, a Part 91 specific lozenge will be displayed.
As certain features in APDL are not applicable to Part 91 operations, some pages are disabled.
