The app will then automatically sync with the cloud and pull down your Logbook Pro configuration information and reports generated by the PC. The last phase is whether or not you want to integrate with your device's calendar which is highly recommended. Acknowledge the calendar permissions prompts which will allow Logbook Pro to write events to your calendar such as your flights, medicals, etc. All of this can be configured in Settings / Calendar once in the device as outlined later in this documentation. Setup is easy and only takes a few seconds. An Internet connection is required.
If you haven't done so already, download Logbook Pro Mobile to your device from Google Play (also available on Amazon.com and Barnes & Noble).
Image Removed Image Removed Image Removed
When you first run Logbook Pro on your Android powered device you will be greeted with the end user license agreement (EULA) and then once accepted you will see a setup guide appear. You must first sign in to your NC Software account using the same account as used in Logbook Pro Desktop (above). The app will then automatically sync with the cloud and pull down your Logbook Pro configuration information and reports generated by the PC. You are now ready to start using Logbook Pro on your Android devices.
urlhttps://www.youtube.com/watch?v=vic9rKKZPUo
urlhttps://www.youtube.com/watch?v=10FgKCvz4vM
