Figure 1. iPad with Logbook Pro and APDL in Split-View mode
In iOS 9 and later for supported devices such as iPad Air 2, iPad Pro, and later Logbook Pro supports Split-View and Slide-Over.  Drag from the right side of the screen to initiate slide-over.  On the left vertical edge of the slide-over window is a small white vertical bar.  Drag this to initiate Split-View allowing two apps to be viewed side-by-side.
