This page can be used to select the current leg, next leg, or flight time calculator for What If scenarios.
Scratch Pad
The options available in the current leg and next leg sections are identical. They adjust various elements of the current or next leg as appropriate.
In the example below, the flight has departed the gate and is informed of a long delay for a wheels up time. The Estimated Off Time has been edited to reflect the wheels up time. In this case, the user is also alerted that they would be approaching a legality limit as a result of this delayed What If scenario.
Legality Report
What If adjustments are reflected in the Legality Report which can be viewed by tapping the report icon at the upper right of the What If or Legality Status pages. See the Legality Report LegalityReport page for details.
Flight Time Calculator
The Flight Time Calculator can be used to alter the amount of flight time you expect to do during your duty period. You can enter an amount of time already flown as well as an amount remaining to fly and have APDL calculate the total duration and evaluate that against 117 Table A limits. These values are automatically filled with your actual flight time values for the current duty period for you to adjust, or you can create your own custom scenario by adjusting both values.
