Comment: Published by Scroll Versions from space APDLDOC and version 8.1.0
APDL is designed to automatically select the appropriate regulation based on the events you have entered for each duty period. If the automatic regulation selection cannot determine the appropriate regulation from your entries, it will revert to the default regulation selected. Regulations can always be manually selected on the .Leg View v7.Next if necessary.
