Welcome to Logbook Pro Mobile
Logbook Pro Mobile brings you the world leading pilot logbook software solution used by tens of thousands of pilots across the globe. Logbook Pro is the most reliable, trusted, and accurate flight logbook software for pilots used in the aviation community for over 19 years. Logbook Pro enables you to log your Certificates, Ratings, Medicals, Flight Reviews, Historical data, and Flights (actual or sim) and view detailed and extensive reports. Import airline schedules and integrate with your device's calendar for reminder notifications and scheduling deconfliction.
The Logbook Pro Mobile app is FREE allowing you to explore Logbook Pro both on the App side as well as the Desktop side prior to purchase.  We know you will love this app which makes flight logging a breeze.
Synchronization to Logbook Pro Desktop edition is effortless and seamless and fully automated when enabled.  Go to your personal “Cloud Sync” portal at http://nc-software.com/sync and preview your pending synchronizations and make modifications online before syncing them into Logbook Pro Desktop edition. No messing with Wi-Fi or cables; it doesn’t get any easier than this.  It is 100% reliable and you can even sync multiple times without the fear of duplicated information or lost information.
Features at a glance:
  • Efficient user interface, no hassle with back and forth screens and slow pick lists
  • Soothing color scheme making data easy to read and less fatiguing
  • Log Certificates, Ratings, History Items (Medicals, Flight Reviews, etc.)
  • Log actual and sim flights
  • Auto Night in both Flight Logging and Schedule Importing
  • View when expiring events (medicals, currencies, etc.) expire instantly on your device
  • Calculate duration from OUT-IN or TAKEOFF-LAND times with the tap of a button
  • View powerful and comprehensive reports generated by Logbook Pro PC edition right on your device
  • Show currency status with colored marker flags indicating current or expired
  • View your details summary bar report
  • Analyze complete logbook statistics with both totals and percentages
  • View FAR 121 limitations with colored markers (requires Logbook Pro Professional Edition or higher)
  • View FAR 135 limitations with colored markers (requires Logbook Pro Professional Edition or higher)
  • Auto-enter the duration value in other time fields with a single tap
  • Customizable cascading time entries for Out, Takeoff, Landing, and In making flight entry quick and easy
  • New flight entries can default with prior flight entry data for rapid flight log entry
  • Customize the layout to declutter display showing only fields you need
  • Advanced synchronization with your Cloud Sync portal at nc-software.com/sync
  • Fully automated synchronization both on the PC side and device side keeps your device and PC updated effortlessly
  • Device uses colors to identify current and overdue, synchronized or not.  No need to purge, the device manages your data smartly
  • Instant filter in each data area to show:  All Data, Not Yet Synchronized, Synchronized
  • Free form route entry allows a single entry for the entire day; no hassle with picking or searching for airports
  • AutoFill makes populating common time fields a breeze
  • Track multiple approaches of each type for each flight
  • Log "By Leg" or "By Day" allowing you to collate your entire day into a single flight log entry
  • Import Airline Schedules from your personal cloud storage at http://nc-software.com/schedule
  • Add new airline trips directly on your device without having to go to the web portal
  • Integrate with your device's calendar
  • Password protect your app from unwanted access
  • High speed, efficient database design for reliable and responsive operations
  • Quick increment buttons to easily add/subtract values for fields such as landings, approaches, etc.
  • Extremely customizable with a ton of options to make the app into what you need
  • Put your app in a specific time zone or choose "Device Local" or "UTC"
  • Sync data back to Logbook Pro Desktop edition in a custom time zone
  • Easily retrieve weather (METAR and TAF) for one or multiple destinations
We know you'll enjoy Logbook Pro on your favorite mobile device.  Within seconds your flight is logged and synced to the cloud and to your Desktop master logbook file.  If you have any questions or need any assistance feel free to contact us.
