Sync is triggered in Logbook Pro Desktop from the Cloud Sync button on the toolbar from within you can click Sync Now. You can also enable automatic sync to sync on startup and shutdown. From Logbook Pro Mobile you can sync from various places. On the top of the home screen and various other screens.
You can also sync from the menu in most screens.Logbook Pro Mobile is used to add new DATA which synced to the cloud and then into Logbook Pro Desktop and also to view Reports. After adding or editing data on your device in Logbook Pro Mobile sync to the cloud manually or use any of the options in Settings/Synchronization. You can, if desired but not required, login to http://nc-software.com/sync and see your device data staged in the cloud awaiting pickup by Logbook Pro Desktop. Either via scheduled sync, automatic sync, or by clicking Cloud Sync / Sync Now in Logbook Pro Desktop the data will be brought down from the cloud and can then be viewed in Logbook Pro Desktop.
