This guide will help you get up and running on your Logbook Pro Mobile equipped devices. Before you can use your mobile device you must link it to Logbook Pro Desktop. If you don't have Logbook Pro Desktop installed click here to download and install it to Windows at this time. If you're using a Mac refer to this article for assistance.
| Anchor |
| desktopinitialization |
Logbook Pro Desktop Initialization
Image AddedNow that you have Logbook Pro Desktop installed and initially setup after first running it if you haven't already been using it you simply need to sync Logbook Pro Desktop to the cloud to upload your master configuration data and reports for your devices to pick up.
| Panel |
| Widget Connector |
| width | 960 |
| url | https://www.youtube.com/watch?v=r01E7bWnrxE&list=PLt5jhPpkokeL_tIjuwYkE8M-Q8Lq3sBDq |
| height | 540 |
Mobile Device Initialization
Image AddedIf you haven't done so already, download Logbook Pro Mobile to your device from Google Play (also available on Amazon.com and Barnes & Noble).
| Widget Connector |
| width | 960 |
| url | https://www.youtube.com/watch?v=vic9rKKZPUo |
| height | 540 |
Please note that Logbook Pro Mobile is not a stand-alone logbook. The lightweight high speed and highly reliable mobile apps are designed to allow you to add new information while away from your PC and easily sync via the cloud. Reports are generated by your PC to encompass your entire logbook. DATA is one way sync from device to cloud and once synced can be purged from the device as the data is no longer necessary or used by the app.
