Comment: Published by Scroll Versions from space LPMD and version 9.0
To use the full screen real-estate in Logbook Pro you can hide the top status bar with the time, network information, etc. Enable full screen mode as shown below. To also hide the bottom bar which contains the device soft keys to hide the keyboard, go back, return to the device home, etc. choose the hide nav bar option. You can show the top or bottom bars at any time if hidden by swiping from top down or bottom up.
security
security
SecurityImage Added
Access to your device can be controlled by a password set in the device's settings area.  To set a password enter your password in both the Password and Confirm boxes.  Your password is now set and the next launch of your app you will be prompted to enter a password to access your app.  As Android keeps apps running in the background 10 minutes between use will trigger a password on the next use of the app.  If you forget your password you will need to delete the app and reinstall it.
Remove your password to remove password protection of the app.
homecounters
homecounters
Home Screen CountersImage Added
The Home Screen counters are the numbers on the far right of each Data Entry area row such as to the right of Flights above. They represent the total number of entries that are on your device. Tapping the setting at the bottom of the main settings screen for home screen counters allow you to control what this value represents such as to include already synced data, show only unsynced, or all regardless of synced or not.
