Logbook Pro Mobile syncs data between your app and Logbook Pro desktop extremely fast through your NC Software account via NC Software's high performance cloud infrastructure.  The available settings related to Synchronization are outlined below.
When the app starts or resumes, if an Internet connection is available, Logbook Pro will sync with the cloud.  Sync takes typically less than one second.  A green bar will fade in and fade out at the top of the screen to indicate synchronization occurred.
Sync Automatically
New in Logbook Pro for Android 7.0 is an automatic sync feature. While the app is running the app will sync every 5 minutes. When the app is suspended the app will sync every hour allowing the app to resume up to date with the latest information from the cloud.
Sync Pending Flights
The default option is not to sync Pending Flights, i.e. flights not yet flown typically used by airline pilots importing future flights via the schedule importer.  However, for airline pilots, etc. that may need their FAR 121/135 reports updated to reflect future flying to check limits syncing pending flights may be of value.  Set ON to allow pending flights to be synced.  Note:  As Logbook Pro desktop reviews your flight log for erroneous entries, i.e. a row of information that does not meet the minimum required fields of Date, Type, Ident, Route, and Duration (or SIM) pending flight data could be auto purged on the PC side.  If you set Sync Pending Flights to ON you should go into Logbook Pro desktop's Options/Flight Log area and clear the bottom most checkbox.
Set the desired time zone for the Flight's OUT, Takeoff, Landing, and IN (OOOI) times to one of the three options:  Device Local, UTC, or Custom.  Data will be converted to this time zone when synced back to Logbook Pro desktop.  Click here to learn more about time zone options.
Reset all data to Unsynced
urlhttps://www.youtube.com/watch?v=2CsAz4TJn6o&index=3&list=PLt5jhPpkokeLZIjEa5ktNSjDcSsT2zIln
