Settings Checklist is designed to be a quick start guide for new users to get the basic APDL settings configured quickly. The Settings Checklist can also be used periodically to keep aircraft types, tailsaircraft, and crewmembers lists up to date if desired.
Aircraft Types associated with your airline can be imported to prepopulate your aircraft types list if desired, or you may skip this step. The same is possible for tail numbers individual aircraft as well as crewmembers as shown below.
You can access these settings for future configuring from the Settings menu. You can also rerun the Settings Checklist at any time by tapping Settings Checklist at the bottom of the Settings menu. if you want to reconfigure these settings, or to load the latest aircraft types, tailsaircraft, or crewmembers associated with your airline.
