Comment: Published by Scroll Versions from space APDLDOC and version 9.0.0
Enter your Base Pay Rate and Per Diem rates for payroll computations.
Image RemovedImage Added
rigandguarantee
rigandguarantee
Rig & Minimum Guarantee
All crewmembers and aircraft tail numbers in APDL are associated with an airline. This allows for easier organization of your data as your career progresses and you, may move on to other airlines and you want to keep your selection lists in APDL as neat as possible and prevent them from becoming excessively large. You can view all crewmembers and tail numbers aircraft associated with your current employer by tapping one of the lines in the Data section.
commute
commute
Commute
