Comment: Published by Scroll Versions from space APDLDOC and version 9.0.0
Check Schedule is our most automated schedule importing solution. It can login to your crew website and check your schedule and import your new trips or changed/swapped trips automatically. It currently supports the following list of airlines which we plan to expand in the future.
Flica users with Mobile Access:
Note
APDL knows if it is capable of using Check Schedule with your airline because of your airline selection in Settings > Airline. If your airline is not supported, the Check Schedule menu item as well as Check Schedule settings items will be disabled. Additionally, if you try to use Check Schedule and it fails, APDL will automatically guide you to an alternate import method the other import methods will typically work if Check Schedule does not.
The first time you tap the Check Schedule menu item you will be prompted to set up your login information in Settings.
