Logbook Pro Mobile communicates with your master logbook "Logbook Pro Desktop" over the cloud. Synchronization is effortless with no setup required. Simply sign in to your NC Software account in Logbook Pro Desktop and also in Logbook Pro Mobile and both are automatically communicating with one another. Logbook Pro Desktop as your master logbook holds your configuration information such as your aircraft types, autofill settings, etc. It also generates all reports used by Logbook Pro Mobile to encompass your entire logbook, currency configuration, and other relevant information to view at a glance in Logbook Pro Mobile on any supported device. Every time you sync Logbook Pro Desktop it pulls down any new data submitted from Logbook Pro Mobile, updates your logbook, generates new reports and currency status and then uploads the refreshed data to the cloud, all within only a few seconds.
The cloud keeps your data in sync between multiple Logbook Pro Mobile synchronizations. You can sync, edit or add entries, and then resync. Once Logbook Pro Desktop syncs with the cloud the data is pulled down from the cloud and inserted into Logbook Pro Desktop. You can still make changes on the device and resync and Logbook Pro Desktop will update the entries based on your changes. Synchronization is extremely reliable and efficient.
Sync is not a backup as the cloud does not retain your data once it is transferred into Logbook Pro Desktop. If interested in a Cloud Backup solution for Logbook Pro Desktop to keep your entire Logbook Pro data in the cloud safe and secure, click here.
To learn about the Cloud Sync Portal click here.
The Synchronization Process
Sync is triggered in Logbook Pro Desktop from the Cloud Sync button on the toolbar from within you can click Sync Now. You can also enable automatic sync to sync on startup and shutdown. From Logbook Pro Mobile you can sync from various places. On the top of the home screen and various other screens.
Logbook Pro Mobile is used to add new DATA which synced to the cloud and then into Logbook Pro Desktop and also to view Reports. After adding or editing data on your device in Logbook Pro Mobile sync to the cloud manually or use any of the options in Settings/Synchronization. You can, if desired but not required, login to http://nc-software.com/sync and see your device data staged in the cloud awaiting pickup by Logbook Pro Desktop. Either via scheduled sync, automatic sync, or by clicking Cloud Sync / Sync Now in Logbook Pro Desktop the data will be brought down from the cloud and can then be viewed in Logbook Pro Desktop
Synchronization is simple using the Cloud Sync portal at http://nc-software.com/sync. Data is exchanged between Logbook Pro Desktop and your device through this portal in the cloud. All synchronization is done over the Internet (The Cloud), there is no need for Wi-Fi home networking or cables. It is fast, reliable, and easy. To initialize Logbook Pro Desktop and your App review the Getting Started topic.
Synchronization Settings
At the top of the settings area enter your Account ID and Username to enable synchronization with the Cloud Sync portal and Logbook Pro PC edition paired with the same credentials. It is recommended to enable Automatic Sync on Start and Exit. Synchronization receives updated data from Logbook Pro PC edition which includes your aircraft types, history events, custom column configuration, and report data.
Once data is sent to the Cloud Sync portal from the device it is no longer needed and can be purged or you can leave it on the device for future reference if desired. Items that have been synced will changed from Black to a Gray. If you want the Sync system to remove synced data after being sent to the Cloud Sync portal you can enable Purge Synced after Sync. This only deletes the already synced data associated to Certificates, Ratings, History, and Flights on the device. As it will not be synced again unless edited it is also safe to leave the data on the device. Pending flights are only synced if optioned to do so in the Settings/Synchronization area.
Synchronization occurs either by tapping "Sync" on the upper left of the Home Screen or if enabled in the Synchronization Settings area, on Startup and/or Exit of the App. After synchronization you can view the data online at http://logbookpro.com/sync. The Cloud Sync portal shows data pending synchronization with Logbook Pro PC edition. Once Logbook Pro PC edition syncs the data is removed from the Cloud Sync portal.
Data items in the four data areas will change from Black to Gray indicating the data has been synced. If you edit the data on the device it will change from Synced to Unsynced and be sent to the Cloud Sync portal at next synchronization. If the data still resides on the Cloud Sync portal it will get replaced with the changes from the device. If you synced Logbook Pro PC edition it will be replaced when the item is resynced. Data that resides in Logbook Pro Desktop is not sent to the device as the data as once data is entered into your log it is "in the books" and should not be touched. Your data is now represented by the Reports which report on your logbook inputs.
If you wish to add data to the device such as a prior Certificates, Ratings, and History items which already exist in Logbook Pro PC editionDesktop, be sure to check the "Synchronized" item at the bottom of the data entry screen when saving. By manually marking an item as Synchronized it will not be sent to the Cloud Sync portal but remain on the device for reference. Flights marked as "Pending Flight" are not synced until the "Pending Flight" check mark is cleared and flight saved unless optioned in Settings/Synchronization to also sync pending flights.
Purge
Once data is synced and verified accurate in Logbook Pro Desktop the data is of no use on the device. It is not used for reports, etc. therefore to keep the device running fast and reliably you should purge synced data. in the menu is the option to Purge from which you will be presented with options, one of which is Purge Synced.
Choose the Purge Synced option to quickly purge only the synchronized data marked as flown (non pending).
Logbook Pro on your device offers several options relating to purging data. You can manually purge within each data area by tapping the button on the lower left, or you can purge data on the top right of the Home Screen. You can also enable Automatic Purge in the Synchronization Settings area which will purge synced data after a successful synchronization. As Logbook Pro PDA Companions are add-only devices, i.e. they do not host your complete logbook data, once the data is synced it is no longer needed. Reports are not tied to the device data as they are snapshots of your PC log data. Reports are not affected by purge operations. When tapping the Purge button you will have the option of purging all data or only synced data (or pending in the Flights area).
