Sync Automatically
New in Logbook Pro for Android 7.0 is an automatic sync feature. While the app is running the app will sync every 5 minutes. When the app is suspended the app will sync every hour allowing the app to resume up to date with the latest information from the cloud.
Sync Pending Flights
| resettounsynced |
| resettounsynced |
Reset all data to Unsynced
width | 960 |
url | https://www.youtube.com/watch?v=2CsAz4TJn6o&index=3&list=PLt5jhPpkokeLZIjEa5ktNSjDcSsT2zIln |
height | 540 |
