Comment: Published by Scroll Versions from space LPMD and version 8.5
  1. Enable AutoFill ON
  2. Route of Flight in a FROM-TO format using ICAO, IATA, or FAA codes such as KRIC-KCLT (single leg only i.e. two airports max)
  3. Takeoff/Landing times and/or OUT/IN times (all four provides the best solution such as for airline pilots that log both block and flight)
  4. Tap the calculate button next to Duration which will determine the duration from the times set in #2 above
  5. An Internet connection is required as the Auto Night is sent to the NC Software Cloud for instantaneous processing. (this will be enhanced to be done completely in-app in a future update)
autonightlanding
autonightlanding
Auto Night Landing
