Image Removed
Aircraft types are typically added in the Options/Aircraft area of Logbook Pro Desktop.  The aircraft types are then synced to your device for use in adding new flight records.  If you are away from your PC you can add aircraft types in the "My Aircraft" area accessed from the Home Screen.  After syncing your device data back to your PC the new aircraft type will be added to the Options/Aircraft list, however, you will be prompted to complete the configuration such as specifying the category, class, etc.
