Comment: Published by Scroll Versions from space APDLDOC and version 8.1.0
APDL can generate a resume for you in several different formats.
Go to Settings/Resume to configure the resume data you would like to be included. Alternatively, you can tap each section on the resume itself to customize the data for that section.
Note
titleNote
APDL includes hint text in the resume settings area to guide you on what kind of information and where to enter it for proper formatting. If you do not wish to use all of the fields provided make sure to review all settings areas and delete the unused hint text, otherwise it will show up in your resume.
Your resume data is automatically formatted into several common resume layouts. You can tap the title of the resume format at the top of the screen in order to select a different format.
Tap the share button at the top right of the screen for resume sharing options.
