Comment: Published by Scroll Versions from space APDLDOC and version 8.4
The Flight Duty Period section displays your FDP begin time, end time, and FDP duration (actual).
Image Modified Image Modified
Any issues will be colored yellow or red accordingly.
The 117.13 Table B (or C) limit row displays the FDP limit according to Table B or C accordingly. APDL automatically determines your Table B or C FDP limit by using your FDP begin time, number of segments, and number of segmentscrewmembers entered for the flights or regulation selected in Trip View.
The Limit Remaining row displays the most restrictive limit affecting your FDP during that duty period. This will usually be the 117.13 limit from Table B or C, however, this could also be derived from any of the FDP cumulative limits if one of those is closer to the limit than the applicable Table B or C limit. If this is the case, you can consult the Cumulative Limits charts at the bottom of the page to identify the problem.
