Comment: Published by Scroll Versions from space APDLDOC and version 8.5.0
Alerts are displayed within APDL while the app is open. Use caution not to confuse APDL Alerts with iOS Notifications. Both APDL Alerts and iOS Notifications can be configured in Settings/in Settings > Notifications.
If you are using the app while an alert is detected, you will see the alert slide up from the bottom of the screen. Alerts will remain on screen until dismissed. To dismiss an alert simply tap on it the X at the right side. Alternatively, you can swipe left or right to dismiss. Tapping the alert itself will take you to the alert rather than dismissing the alert.
