Comment: Published by Scroll Versions from space APDLDOC and version 8.5.0
https://www.youtube.com/watch?v=Jc6V1BpGs_0&list=PLt5jhPpkokeL7jZrgoINs1synCP7F3iAy&index=11
graph
graph
GraphImage Added
The summary graph shows your scheduled versus actual block time per month. Dates in the past are calculated using actual block values and are indicated by a shaded green area on the graph. Dates in the future are forecast using actual and scheduled block times and are indicated by a dashed green line on the graph.
chart
chart
ChartImage Added
After the graph you will find specific summary information broken down into various items. On iPhone this chart is below the graph while on iPad it is beside the graph.
  • Scheduled Block in hours and minutes
  • Actual Block in hours and minutes
  • Night time in hours and minutes
  • Instrument time in hours and minutes
  • Landings
  • Legs Flown
daterange
daterange
Date RangeImage Added
Excerpt Include
Productivity Forecast 1
nopaneltrue
tripdetails
tripdetails
Trip DetailsImage Added
Below the chart area is a section containing specific trip details. This section is collapsed by default. Tapping the Trip Details row will expand it.
Note
titleNote
Number of legs displayed in the Trip Details section is NOT the same as the number of segments for determining FAR 117 Table B limits!
ontimeperformance
ontimeperformance
On Time PerformanceImage Added
In the On Time Performance section, you can view your performance percentages broken down into the common DOT tracked metrics. These metrics include only flights you actually flew (not deadheads). On Time Performance is also displayed in the year to date summary below.
yeartodatesummary
yeartodatesummary
Year to Date SummaryImage Added
The bottom of the Summary Page displays a Year to Date Summary. This section is always visible regardless of the Trip Details section above being collapsed or expanded. The year is based on the current date range and is displayed in blue.
