Sync Automatically
New in Logbook Pro for Android 7.0 and later is an automatic sync feature. While the app is running the app will sync every 5 minutes. When the app is suspended the app will sync every hour allowing the app to resume up to date with the latest information from the cloud.
Sync Pending Flights
Time Zone (Sync in)
| resettounsynced |
| resettounsynced |
Reset all data to unsynced
width | 960 |
url | https://www.youtube.com/watch?v=2CsAz4TJn6o&index=3&list=PLt5jhPpkokeLZIjEa5ktNSjDcSsT2zIln |
height | 540 |
