| Scroll Ignore | ||||||||
https://www.youtube.com/watch?v=FGIMCzfGiYc&list=PLt5jhPpkokeL7jZrgoINs1synCP7F3iAy&index=245&pp=gAQBiAQB
APDL offers 4 different methods to import your schedule. All these methods are described here and listed below from most automated to least automated.
| Note | ||
"Trip Blending" where a partially flown trip is modified and reimported on top of itself is not currently supported. You cannot import a trip on top of any portion of an existing trip where flights have already been closed out. |
| Anchor |
Download Schedule
Check Download Schedule is our most automated preferred schedule importing solution. It can will direct you to login to your crew website and check your schedule and from within APDL. Tap Download Schedule at the top of the screen. Next, navigate to your schedule data on your crew website and tap the down arrow Page or down arrow pairing button to import your new trips or changed/swapped trips automatically. APDL knows if it is capable of using Check Schedule with your airline because of your airline selection in Settings > Airline. If your airline is not supported, the Check Schedule menu item as well as Check Schedule settings items will be disabled. Additionally, if you try to use Check Schedule and it fails, APDL will automatically guide you to an alternate import method which will typically work if Check Schedule does not.
The first time you tap the Check Schedule menu item you will be prompted to set up your login information in Settings.
Enter your username and password to have APDL login to your crew website and check your schedule for you.
| Note |
Your login information is saved in the device's secure encrypted keychain. Your information is not sent to NC Software nor is NC Software able to retrieve it. This requires you to enter this information on all devices you wish to use the Check Schedule feature with APDL. |
Tap "Test Login" and APDL will attempt to login and download your current month's schedule. If successful, Check Schedule is enabled.
If you enable the "Check Periodically" option, Check Schedule will periodically check for schedule changes once every 24 hours, and at least 1 hour prior to your show time. The spinner is displayed when Check Schedule is running. You can also tap Check Schedule in the menu to manually check for schedule changes.
If you wish to disable Check Schedule temporarily for some reason, such as a modified schedule that isn't reflected correctly on your company website, you can just disable "Check Periodically" and Check Schedule will only run when you manually tap the Check Schedule menu item.
If APDL is not open when changes are detected, you will receive an iOS notification.
without ever leaving APDL. Make sure your crew website URL and ID Number are set for this to work properly.
Tap any of these notifications to review the changes detected as described in the Reviewing Data to Import section above.
| Anchor | ||||
To import your schedule using the Importer within APDL, select "Import Trip" from the menu. Tap "Copy, Paste and Process, Scan".
This will display a simplified version of the Schedule Importer Portal.
Paste your trip data and tap Process You can paste your trip data directly for processing using the paste button at the top left. Tap the process button at the top right to process the data.
| Note |
Make sure you have selected the appropriate time zone and filter in Schedule Importer Settings to match your company provided schedule data! |
