Comment: Published by Scroll Versions from space APDLDOC and version 14.0
Scroll Ignore
urlhttps://www.youtube.com/watch?v=Jc6V1BpGs_07K1Qq8irblI&list=PLt5jhPpkokeL7jZrgoINs1synCP7F3iAy&index=17&pp=11gAQBiAQB
https://www.youtube.com/watch?v=Jc6V1BpGs_07K1Qq8irblI&list=PLt5jhPpkokeL7jZrgoINs1synCP7F3iAy&index=11
The summary graph shows your scheduled versus actual block time per month. Dates in the past are calculated using actual block values and are indicated by a shaded green area on the graph. Dates in the future are forecast using actual and scheduled block times and are indicated by a dashed green line on the graph.
=17&pp=gAQBiAQB
The Summary page allows you to view a summary of your flying over several time periods, including the ranges required by MedXPress.
Image AddedImage Removed
chart
chart
Chart
After the graph you will find specific summary Each page displays summary and on time performance information broken down into various items. On iPhone this chart is below the graph while on iPad it is beside the graph.
Image Removed
Summary items includeAmong these items are:
  • Scheduled Block in hours and minutes
  • Actual Block in hours and minutes
  • Night time in hours and minutes
  • Instrument time in hours and minutes
  • Landings
  • Legs Flown
  • Legs Flown
  • Day & Night Landings
The On Time Performance section displays
The Recent Experience section shows your landings within the last 90 days and when your landing recency will expire. This is also available on the Alerts view as well as the Legality Detail view.
Image Removed
Below the chart area is a section containing specific trip details. This section is collapsed by default. Tapping the Trip Details row will expand it.
Image Removed
The Trip Details section displays summary information for every day with data entered into APDL. Available data includes:
  • Number of legs
  • Number of landings
  • Total block in hours and minutes
The last row of the Trip Details section displays the grand total of each column for the entire date range.
Note
titleNote
Number of legs displayed in the Trip Details section is NOT the same as the number of segments for determining FAR 117 Table B limits!
In the On Time Performance section, you can view your performance percentages broken down into the common DOT tracked metrics. These metrics include only flights you actually flew (not deadheads). On Time Performance is also displayed in the year to date summary below.
Image Removed
The bottom of the Summary Page displays a Year to Date Summary. This section is always visible regardless of the Trip Details section above being collapsed or expanded. The year is based on the current date range and is displayed in blue.
Image Removed
Image Removed
You will find specific yearly summary information broken down into various items. Among these items are:
On the Bid Period Summary page, you can cycle between bid periods using the left and right arrows at the top of the screen. Tapping the calendar icon in the center of the arrows will return to the current bid period.
daterange
daterange
Custom Date RangeImage Added
You can use the custom date range page to designate a custom date range if desired.
medxpress
medxpress
MedXPressImage Added
The MedXPress page displays the lookback timeframes needed for filling out a MedXPress application.
In order to get the correct value for total time to date, you must enter all your previous flying time prior to using APDL in the Settings/Aircraft section under "Previous Time". This must be done for all flying that takes place which isn't logged in APDL either prior to when you started using APDL for the first time, or any outside flying that you choose not to log in APDL. The easiest and quickest way to accomplish this is to create a new "Aircraft Type" and label it "prior flying" or something similar. Then enter all your total hours prior to using APDL, in all aircraft types, into the "Previous Time" row. These hours won't be used for any calculations within APDL except these lookback reports. You can also choose to archive this "Aircraft Type" and have archived items hidden from view by deselecting "Show Archived Data" in Settings/General.
