- § 117.11 Flight time limitation.
- § 117.13 Flight duty period: Unaugmented operations.
- § 117.15 Flight duty period: Split duty.
- § 117.17 Flight duty period: Augmented flightcrew.
- § 117.19 Flight duty period extensions.
- § 117.21 Reserve status.
- § 117.23 Cumulative limitations.
- § 117.25 Rest period.
- § 117.27 Consecutive nighttime operations.
Legality Status
Legality Status is based on all Leg activities entered for a Duty period on the Trip View or Logbook ViewLogpage Views, or imported via the Schedule Importer.
Legality Status is displayed throughout the app using the following lozenges.
Status | Description |
Duty period meets all 117 requirements * | |
Current Duty Period has Legality Issues | |
Future or Past Duty period has/had legality Issues |
The Legality Status found on the main menu indicates your status for the current or next duty period.
When navigating a sequence in Trip View, the Legality status for each duty period is shown on the first row.
In this example day one is legal. Day two has two issues that need attention. Tapping on the Legality Status on any screen will open the Legality Status View.
Duty Period and Legs
Each Duty Period is represented with a Duty On and Duty Off time.
Note | ||
All Flight crewmember Flightcrew member responsibilities and assignments assigned by the certificate holder must be logged as a duty period to accurately analyze your legality and provide a Legality Status. |
Payroll
Types and Legality
APDL Contains a number of pre-defined Payroll categories types to categorize your duty. Payroll categories types in APDL identify the tasks that a flight crewmember flightcrew member performs as required by the certificate holder, including but not limited to flight duty period, flight duty, pre- and post-flight duties, administrative work, training, deadhead transportation, aircraft positioning on the ground, aircraft loading, and aircraft servicing.
The basic payroll categories types that you will use most often with Legality are :
- Block - Scheduled or Actual flight segment
- Deadhead - Flight crewmember Flightcrew member is a passenger or non-operating flight crewmemberflightcrew member, by any mode of transportation, as required by a certificate holder, excluding transportation to or from a suitable accommodation.
- Canceled - Scheduled flight segment has been canceled.
- Short-call Reserve - Flight crewmember Flightcrew member is assigned to a reserve availability period.
** See the Payroll Settings Section Section for a complete list of Payroll categories Types and settings.definitions
Payroll categories types are the primary way of identifying the overall regulation operation type for each duty period.
Each leg also contains a Regulation section. By default, Regulation for each leg is Automatic.
With Automatic selected, the regulation type used to compute your duty period legality is based on the most restrictive leg type.
- Reserve and Augmented Crew = Part 117 Augmented Reserve
- Any Split Duty = Part 117 Split Duty
- Reserve = Part 117 Reserve
- Augmented Crew = Part 117 Augmented
- Unaugmented Crew = Part 117 Unaugmented
- Part 91
- If APDL can not determine the Operation type it will default to your selected default Regulation in Settings/Regulations.Part 117 Unaugmented
For most operations you define under payroll, the automatic Regulation Type does not need to be changed.
Special Cases
Some Reserve, Split Duty, Consecutive Nighttime operations, and Augmented operations are special cases that need additional data to compute your legality correctly.
Reserve
If you are importing a trip the default import payroll option is "Block". If you are on reserve you have two choices, you can set the first leg of your trip to Short-Call Reserve or you can Override the operation Type
Trips imported via the the schedule importer will default to
You can configure the trip for reserve in one of two ways. For the first leg in the duty period either :
Set the Payroll category to reserve (short call, long call, or airport standby) - this is the preferred method,
Select Part 117 Reserve under Regulation Operated Under
In each case the legality engine will select the appropriate reserve type
Split Duty
Each airline codes split duty pairings a little differently. Schedule importer looks for a leg with identical city-pairs. When imported the time identified in the Split Duty Rest does not include ground time to or from rest facility.
If you need to add a split duty rest. Create a leg with identical city pairs. Then set payroll to Rest Opportunity.
Part 117 Split Duty will not be selected if the rest opportunity is less than 3 hours.
When viewing the Legality status screen you can override both crew complement and rest facilities under the assumptions section.
Assumptions
An assumptions section was added to the top of the Legality view to accommodate information that can not be fully gleaned from the logbook entries.
- Acclimated Theater: An assumption is made for where the flightcrew member is acclimated, but if the assumption is not correct , the acclimated theater, or airport, can be changed.
- Acclimated Time: As with Acclimated Theater, it is not known exactly when a flighcrew member has been in a theater long enough to be acclimated per § 117.3 Definitions. This alters the start time when calculating FDP and flight time.
- Flight Segments: If additional flight segments are to be flown that are not yet entered into APDL, that can be adjusted here.
- Acclimated: Indicates the flightcrew member is acclimated to the scheduled theater. If, for any reason, this is not the case, that can be indicated here. For the most part this reduces maximum FDP for a duty period.
- Two buttons at the bottom of the Assumptions section are available were added to recalculate and reset the assumptions.
Sharing Legality Information
At the upper right of the Legality Status Page is a share icon. If there is any question or concern about your Legality status, you can send a PDF copy of legality information via email, text message, and more.
