Several widgets can be tapped to interact. This can change the information displayed on the widget such as cycling between local time and UTC or open a new page for editing a flight or viewing Legality Status. You can also pull down to refresh the Status Board at any time.
Anchor Clock Widget Clock Widget
Big Clock
Clock Widget | |
Clock Widget |
The big clock widget displays the current time in UTC and your domicile time zone.
Tapping the clock widget will switch the location of between UTC time and your domicile time.
Gate information for departure and destination airports.
The Trip Route Map widget will display the same route map that is available at the bottom of the trip view. Tapping the map will take you to the full screen Weather Map view.
Plus More...
We aren't done adding more useful widgets... We invite ideas for the Status Board that may be added over time. Any suggestions for widgets may be submitted at apdl.uservoice.com
